throttle stop
hi all ive just joined the site, i would like to now how much should i cut of on my throttle stop on a 04 250wrf, thxs jon.....
hi jon were in the uk are u any were near manchester? welcome to thumper talk :naughty:
0.975" (24.765mm) or a stem length of 0.790" (20mm) in order to match the YZF's
I crudely cut down the original with a hacksaw to about 24.75mm and polished off the rough spots, then put back in. It worked just fine and has worked fine, since. Happy ridin'!
I just had this done on my '04 WR. The shop manager said they just take it out completely. Have fun, it's a wild animal without that stop!!
clearly the shop manager doesn't know the ill effects of leaving it out.
jim aka the wrooster
'01 wr250f
'01 wr250f
what happens if you leave it out then ?..
well ive just cut it down so theres 20mm left on the tread.
hi gaz, im down in sunny devon..
from a prior post in this thread
which, when you scroll down, will take you to lots of informative threads...
e.g.
http://www.thumpertalk.com/forum/showthread.php?t=86260
and the last post in this thread
http://www.thumpertalk.com/forum/showthread.php?t=198803
and finally, see this thread, which has tons of info in it for you...
http://www.thumpertalk.com/forum/showthread.php?t=204615
and really finally, read through this thread,
http://www.thumpertalk.com/forum/showthread.php?t=215250
'01 wr250f
I 2nd the motion to put a throttle stop back in. If you do not want to cut the WR's down then just buy one from a YZF. Either way, put something in there.
cheers for the responce peeps, its all cut down now..
