how to get more air
Hey, i was wondering how to get more air into the carburator at home and the jetting i need to know.
Thanks, Ryan :naughty:
pull the backfire screen and the snorkle.....the jetting is at one of the top two stickeys for whichever bike you have
hack off the air box cover for more air flow.
You could remove the whole seat & air box the carburator is still only 26 mm.
what bike do u have umm but if crf 150 put 110 main and 42 pilot and take snorkel andothe resticter s out
Yup. Unless the air isn't using the whole 26mm, you aren't doing jack squat.
Cutting the airbox screen is a no-no unless you invest in a flame retardent air filter.
Bore that Baby! Port that Head. Throw caution to the wind and just remove the whole airbox.
Hook up a shop vac to blow air into the carb.... think about it... you wouldnt need a filter... would be a little heavy.... I guess I gotta work the bugs out of that idea...
On a serious note, I wouldnt go much beyond removing the snorkel and maybe opening up the top of the airbox a bit. If your ridding in alot of mud this might be bad idea (cutting the top of your airbox) but most race bikes are like that, so on groomed tracks it should be just fine.
