3 mods for mellow desert riders
I’m old and slow, so you racer types can hit your back button now. This won’t interest you. :D
I did 3 things to my 250X that really transformed it for me. By riding style, I’m inbetween an XR and the CRF. But after riding a CRF there’s no going back.
First thing I did was the Rekluse clutch. That thing is just about a miracle in it’s own right. The bike won’t stall in tight stuff, it makes the throttle much easier to feather, and it transforms the motor into a strong pulling at low revs - don’t have to shift it nearly as much - pleasure. Yeah, you can play with the clutch lever yourself, but this does it better. (do a search and all you’ll find are rave reviews)
Next thing was taller gearing because 1st gear is too low. The Rekluse changes the character of the motor that much. My X came with 14 x 53 gearing, I changed to a Renthal 51. 1st gear is more useable, the motor revs less at any given speed, and it rides like the gearbox has a wider ratio. On the trail or open dirt roads, the motor runs easier and smoother. On loose technical climbs, 1st gear winds out over a broader speed range, which works much better.
And the 3rd thing is the engine noise. This motor rattles and clanks and sounds like it’s going to blow when you rev it. I replaced my aluminum skid plate with an E-Line carbon skid plate. The aluminum plate echo’s and magnifies the motor noise, the carbon stops that “kid scratching his fingernails on the blackboard” sound. The bike is much more fun to rev without all that clattering in your face. The skid plate made a way bigger difference than I ever imagined it could. Thank you Rick Ramsey for that sugguestion! :naughty:
These 3 things really changed the bike for me, now I don’t have any XR envy left. OK, maybe valve life? But with everything else going for it, the CRF250X is way too great to ever look back. :naughty::D:D
Scotts Stabilizer, and Cycra Pro Bends. :naughty:
What are Cycra Pro Bends? :naughty:
and- I've never used a Stabilizer. My front wheel hooked a couple of times in the deep sand today and I turfed it. Do they help with that sort of madness?
Good to hear the 51 is working out :naughty: . I just ran across mine in the garage today. BTW, did the stock chain fit?
I've been researching the Rekluse auto clutch. Sounds like a nice thing to have. How does it work on tight downhills where you need compression braking?
The clutch engages based on engine rpm's. You tune it to how you want it to engage / hit. You can adjust it to catch at low rpm's, very quickly, or you can set it to where the motor has to rev more and it comes on softer. It can disengage on a downhill if you allow the motor to drop to idle, like locking up the rear wheel. It won't stall the engine, it will just disengage the clutch and the motor drops to idle. You just give the throttle a little blip and the clutch is engaged again and working like a normal clutch, good engine braking. It's not bad at all.
  • Similar Content
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By DirtRider250x
      Hi all,
      My main question is how can I make my 250r more reliable. I have owned it for 2 years and it was spent about 1 year in the shed probably needing new valves and piston rings (i have been putting it off) Will steel valves last longer and work well in the engine? Also, what are your thoughts of me selling it and buying something newer? is it worth it?
    • By Throttlejockey
      Please post pics only. All other posts will be deleted so it doesn't get out of hand. PM the poster for more info or create a post.
      Violators will get a one day ban from the forum.
    • By bull413
      I checked the valve clearance on my 06 crf250r and both exhaust valves is at .007 and the intake is (left side) .005 and (right side) .000??? idk my feeler gague only went down to .002 and it would not slide in.
      Is that ok for the exhaust? Do I need to just shim the right side on the intake? or does both need shimming?
