Trouble Starting TC450
Hi guys, can anyone educate me on how to start my TC450?
The bike is a new 2004, that I have had less than a month, so I haven’t had a chance to ride it over about 2 miles to date
Approximately 72 hrs ago I apparently flooded the motor, I messed around with it for about an hour that day. The following evening, I attempted to start it again, no luck so I pulled the plug out, it was wet, spun the engine to clean it out, then let it sit for 48 hrs with no plug. I re installed the plug, and it still wont start. It tries, but just spits and sputters at best. I also checked the plug for spark “ouch”, and the petcock valve to make sure it was functioning, etc. The exhaust does get lukewarm from the occasion spitting & sputtering. What am I doing wrong?
The 04s Te and Tc were known for bad starting . The carb is poorly jetted . I had the same problem . What you need to do is to send the carb to halls husqvarna . You can find them on look on the dealer list and click on Illinois state and you can find them there . They do more than change the jets . It will cost about a 100 dollars . Its worth it . I had mine done and my buddy had both of his Tc 450 done . For now what you need to do is pull the choke twist the trottle 4 times and hit the starter . It may take a couple times doing this process . The bike is jetted way to lean from the factory . :naughty:
Cold starts rely on proper procedure; must twist 3-4 times then hit button with throttle closed.
No start after a few seconds? Try again.
Raise the idle by screwing in the idle adjuster 1/4 turn.
They come with a 30 pilot, which is rich. A 27.5 is better but I still havent got one in yet.
Check the fuel screw is at 1.75 turns out. If so, try setting it to 1.5 instead - thats leaner, but the pilot is rich anyway.
If the weather is pretty warm try starting without choke. Mine likes that. Again, rich pilot = chokeless start.
[b[I]]The 04s Te and Tc were known for bad starting[/B] [/i] . The carb is poorly jetted . I had the same problem . What you need to do is to send the carb to halls husqvarna . You can find them on look on the dealer list and click on Illinois state and you can find them there . They do more than change the jets . It will cost about a 100 dollars . Its worth it . I had mine done and my buddy had both of his Tc 450 done . For now what you need to do is pull the choke twist the trottle 4 times and hit the starter . It may take a couple times doing this process . The bike is jetted way to lean from the factory . :naughty:
Wow, I have never heard that one. I have owned two of them and they both started flawlessly. Yes they are jetted lean out of the box. On that point you are correct.
If you go to just about any motorcycle shop you can buy Mikuni large round mains for about $3 each. Put a 185 in it. Raise your needle to the 5th slot from the top. Set AP pre-load to zero and don't touch the pilot. Stock should be fine for more if you like latter. Go to all the threads that heve been posted on the subject for more details.
I'd also skip the twist the throttle deal. Maybe once when cold and never hot. Obviously you are flooding it with a wet plug like you are experiencing.
Try this for me once. Pull out the choke. Do not twist the throttle to prime the carb. Hit the button. Let it idle for 15 seconds. turn off the choke.
IF you have never ridden the bike before and it is brand new: Let it idle for about 5 to 7 minutes at least to let it get good and hot. Then ride it hard with lots of accelleration and decellerations to break it in.
If you don't know how to jet a motorcycle, or don't won't to learn. or just don't want to do it, then send it off and spend $100. You can do it yourself for under $10 guanteed.
There is no mystery to these carbs. Very easy to work on.
Thanks for all the help guy’s; I finally got it running this afternoon. Cleaned it out as much as possible on my little track. Sounds like the re jetting will be inevitable at some point. I figure I have about a month to get it all dialed in before it dries out enough around here to actually go riding away from home. Again thanks a bunch, I will be saving the info for future reference.
  • Similar Content
    • By Bryan Bosch
      Rockstar Energy Husqvarna Factory Rider Starts his Quest to Defend Cross-Country Rallies World Championship
      March 15, 2018 – (Motor Sports Newswire) – Rockstar Energy Husqvarna Factory Racing’s Pablo Quintanilla will re-start his 2018 international rally racing campaign on March 24 to 29 at the Abu Dhabi Desert Challenge in the United Arab Emirates. Working hard towards returning to full competitive fitness following a foot injury sustained during the closing stages of the Dakar Rally, Pablo’s teammate Andrew Short is expected to join the Rockstar Energy Husqvarna Factory Racing squad at the 2018 Merzouga Rally in mid-April.
      With the Abu Dhabi Desert Challenge playing host to the opening round of the 2018 FIM Cross-Country Rallies World Championship, the event in the UAE will see Pablo Quintanilla begin the defence of his FIM Cross-Country World Championship title. Securing eighth overall at the 2018 Dakar Rally in January, the Chilean rally star is already looking forward to a solid return to racing aboard his FR 450 Rally machine.
      Successfully wrapping up his debut participation at the prestigious Dakar Rally with a top 20 result, Andrew Short has been recuperating from a fractured tibia and fibula on his lower right leg. Resuming his training sessions in the middle of March, the American has his eyes set on making a return to racing at the Merzouga Rally on April 15/20, in the dunes of Morocco.
      Celebrating its 28th edition in 2018, the Abu Dhabi Desert Challenge is a six-stage-long rally taking place in the southern part of the United Arab Emirates. Kicking off with the traditional Super Special Stage on Saturday, March 24, the event will continue with five more days of racing in the Liwa Desert before competitors reach the finish line inside the Yas Marina circuit on March 29, 2018.
      Pablo Quintanilla: “Abu Dhabi will be our first race after the Dakar and I’m really looking forward to it. It’d be good to start the season carrying the #1 plate on my Husqvarna as the reigning champion. With it being the first race for the new season, it is important for everybody. My goal is to get a good race pace from the beginning in order to be inside the group of leading riders. The season will be long and my plan is to continue improving my pace as the racing goes on. I want to get back my racing speed and also remain strong throughout the event in Abu Dhabi. Taking place in deep sandy dunes, the Desert Challenge is always a tough event and it is also highly probable that we will have to race in high temperatures. It’s going to be a challenge but I’m looking forward to it.”
      Husqvarna Motorcycles. Tradition on two wheels since 1903.
      Husqvarna Motorcycles are widely known and respected in the off-road world for a heritage of competition and numerous motocross and enduro world championships. Originally founded in Sweden in 1903, Husqvarna Motorcycles have been designed and manufactured in Mattighofen, Austria since 2013.
      Rockstar Energy Drink
      Rockstar Energy Drink is designed for those who lead active lifestyles – from Athletes to Rockstars. Available in over 20 flavors at convenience and grocery outlets in over 30 countries, Rockstar supports the Rockstar lifestyle across the globe through Action Sports, Motor Sports, and Live Music. For more information visit:
      Source: Husqvarna Motorcycles GmbH
    • By DdrossyD
      Looking for some Wiring Harness, Connections and Installation assistance for installing a Tusk Universal Under the Fender LED Taillight with Brake Light on a Husqvarna 2017 TX300
      The UTFLight comes with a plastic connector that would work with the tusk enduro lighting kit which i'll be removing so that I can plug into the stock harness.
      I've been told the stock harness is the same as what would be included on the TE Model, minus the actual headlight/taillight being present; which is the case for the headlight wiring . it's all there ready to go.  For the taillight/brakelight however there is a bit more to be done.  There are NO wires running to the rear of the bike or within the SubFrame as some have noted
      I'll need to run to existing wires, and could use some guidance for which connectors are needed, if a supplementary harness is required(if so which one) and which wires to connect to on the existing harness.  There is very limited info in the manual (for either bike: TE/TX) or complete color harness diagram with info and connector information anywhere that I could find.
      I also picked up the Tusk Brake Switch Banjo bolt for the Brembo brakes (two wire, bullet connectors) - switch instructions.pdf
      On the Brake side under the front/bottom of gas tank near radiator there is an existing connector (I think for radiator fan) and from it, two unused wires, I would say for tapping into the existing harness.  1 Solid Brown, 1 Yellow/Red -
      Shifter side, near the bottom rear of tank I found taped up cylinder style connector (Someone can enlighten me) i think switch wires ? maybe some terminator,  each with the same color wire in as out.  One is Gray/Black and the other White/Black
      Under the cdi box is a three plug connector with two wires, 1 Brown and 1 White, third unused- i was hopeful this could be the tail light connector but am unsure
      Help on harness, connector names /types and setup is very much appreciated
    • By Ride
      ...thought this might be fun as i see a lot of older guys riding Huskys on TT. I'll start...
      41 years old - 93 TC610/99 WR250/02 WR250/04 TE450/04 CR125/06 TC250 (on the way)
    • By Dave Hoder
      I'm just putting the finishing touches on my streamlined version of the BOZZA DRAFT shop manual for the 610. I've removed everything but the english language & made it easy to find what you're looking for. I re-wrote the part about the computer with many thanks to Xfool but I'd like a little proof reading here. In particular I'm not real sure about the Service Interval section. If any of you would be willing to double check what I've got here & report back with any errors or omitions I'd be greatful. (I added another section on adding & removing screens) Also I don't know if it's legal to post this for public consumption but I'd be happy to share it with anyone who want's a copy.
    • By Agitator
      10/17/08 UPDATE! I posted more photos on page 2. Not all pictures are on page 1. I will constantly be adding more photos as I go along.
      Many of you have heard of my starting/idle problems with the 610. Carburetion has been ruled-out time and time again. I sensed something else was going on. The engine has never wanted to idle down, sounded like there was a load on it even in neutral. Since I had metal filings in my oil when I first got it, I have now decided to overhaul it and make everything ship-shape. It turns out that I was correct- there is some valve damage that I will talk about later.
      I don't like to take apart dirty engines and get the dirt inside 'em
      A little gross.
      My cleaning station:
      A little better now
      Clutch removal:
      after removing springs
      bottom of pressure plate
      everything looked decent as far as wear
      after removing plates
      basket after removing hub
      Area after removing basket.
      Removing the starter gear with snap ring pliers
      More to come. I'm uploading pictures of the case splitting, etc...
      I'll try to ease off on the photo-over-obsession. The next batch of info/photos will be a little more interesting.
      Comments and suggestions are appreciated. I'm already ordering parts from George so before I know it, I'll be just waiting on new parts (after a little more cleaning.
