Help!!
I got a XR80 and it needs new rings. I'm not sure how to get the cam chain off and I only see one bolt holding the heads together, so I can't take them off. Am I missing somthing? :naughty:
You get the cam chain off by unbolting the gear from the cam. The four rocker mount bolts are the head bolts. Get a manual.
you are definitly missing something. take all the tension off the cam chain then turn the cam so the first bolt on the cam sprocket is showing, then do the same for the next bolt. Then slide the sprocket out and the chain will drop down so you can pull the head. like klxd said, make sure to remove the 4 rocker mount bolts, and one 8mm bolt on the side of the cylinder.
Thanks guys :naughty:
