Torque settings for subframe?
I loosened the subframe to rotate it so that I could easily re-install my carb after doing the 3x3 mod and putting in the DJ jet kit (with 140 main and 25 pilot). I snugged them up good for a quickie test ride around the neighborhood, but want to have them torqued to spec.
Could someone with a shop manual let me know what the two lower bolts (the ones you remove) and the upper one under the seat (that you hinge on) should be torqued to?
I will be ordering a shop manual on Monday. Thanks!
25.5 ft/lbs for upper and lower
Thanks! I appreciate it!
That is what is nice about having the manuals for all my bikes in a book case right by the computer :naughty:
