Valve Problem?? MXC400
I have a 2001 MXC 400 and it started making a strange noise this weekend and I wanted someone's opinion on the matter. You know the sound a bike makes when its running and the kickstarter is in engaged- the tikky/tapy noise? Well I was riding along and it started making that noise and I thought it was the kicker but it wasn't. I was thinking maybe the kicker mechanism went bad or is stuck on/in position? The other thing it sounds like is the valves are needing adjustment. So I can't tell if its the valves that need adjusting or "piston slap" or what so if anyone has any idea on what it might be it would be most helpful. As for the valves, it seems like the noise would be more gradual and the noise would increase as they needed more adjusting instead of just making noise in the middle of a ride. Thanks-Thomdogg
you would normally hear the valves when idling, probably not when riding with your helmet on. people have been posting that the primary drive nut comes loose and makes noise.
Where is the primary drive nut? and is it difficult to get to/repair or replace??
When is the last time you checked the valves? Only adjusting them if you hear a problem is not a good maint schedule. They need to be checked regularly. Not saying you don't, but just saying.
Primary nut is a left hand threaded nut on the clutch side of the crankshaft.
Another possibility might be cam bearings. Have you ever replaced the cam bearings or the auto-decomp stop bolt?
I haven't had to replace the bearings or any thing internally and I have been keeping regular maintenance on my machine. Is the primary drive nut easy to get to or should I have it taken to a shop and do you think that could be the problem/is that common?? Also, I checked the valves and rocker arms to see if anything may be broken or damaged but they were fine. Thanks for the feed back and all info is a great help.
Primary nut is easy to check. Just order a clutch side cover gasket in case you tear the old one. Then drain the oil, pull the sidecover off (kickstarter and possibly brake pedal will have to come off first) and it's right there.
From the discription of the problem and what the post made by that other guy said, do you think thats what it could be?? I have never herd of that part backing out and making noise. If its not the valves than it makes sense to think that it is the primary drive nut. Thanks again for all your info-thomdogg :naughty:
It could be, sure. It's worth checking as it's not very hard to get to. And it has been reported in the past. Haven't seen it much lately, though.
Thanks Jeb! I will check it out this week. Also, do you know any good on-line shops where I can get a gasket set for my bike??
You said you checked the rocker arms? How much valve clearence did it have? Per your manuel you should be way past due for cam bearings and the cost to update is minor before they fail, after? It can be big.
I get most of my parts from the good guys at Cycle Zone KTM. But this website has a store, too, so check that out.
i've seen this problem with the primary drive gear twice, it really does sound like the motor is history, its simple to fix. As a rule I change my cam bearings every 180 hrs, i know of two instances of bearing failure, again its a simple fix but i think the dealer should do it because its a little complicated
I took my machine to the shop today and the mechanic there thinks it sounds like something in the bottom end-maybe the rod? Just have to wait and see I guess. I will let you guys know as soon as he calls me when they get in side of it. I'm new to ThumperTalk so thanks for all the input and help everybody. Keep tear'n it up out there- thomdogg
p.s- "you gotta rev that sucka! Just rev it up!" -Elvis :naughty:
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
