Transmission Cover - Bearing and Seal
Posted this on Planet KLX also..
Well, I screwed up today. I did the shift star mode by grinding the
shift star (very easy with a dremel tool, thanks for the KLXZone
Link with Pics). That went well and looked great. While putting the
covers back on, I was having a problem seating the transmission
cover. It seemed all lined up so I was going around tightening
evenly. The 10MM nut that is right below the shift lever seemed
tight, but I cranked a little bit more and I heard a little pop and
everything tightened up nicely. All back together and I added oil.
Small drips were coming from around that 10MM bolt.
I took it all back apart and that little pop was the transmission case
cracking!!! Those things are so delicate apparently!!
In any case, I've ordered a new cover, seal and needle bearing from
Bike Bandit. Grand total of $72.00.. That burns me!!!
Now, I'm left wondering how to press in the new bearing and seal
into the transmission cover when they arrive next week. They appear
to pressed in and they don't just push out. I tried tapping them out
of the cracked cover.
What do I do? I'm afraid to tap on these aluminum parts. Help.
Maybe a rubber mallet? I don't really know never had mine apart. But it sounds like maybe something wasn't quite lined up? Hope the new one goes on better.
Aluminum grows quickly when you heat it. If you use a hot plate, put the cover on a sheet of aluminum, and place some motor oil on the case. When it starts to smoke you can remove the case with welding gloves and usually you can insert the bearing. If you use a propane torch, first see if the case can be set up to press the bearing in with a c-clamp. Heat the case around the hole (10-15 seconds only) and put the bearing over the hole using the c-clamp to slowly press it in.
If you want to use the least amount of heat and minimize risk. Identify which side of the case you can lay flat on steel so you support the case over the bearing hole when you apply pressure to the bearing.
Using your best Chinese calipers check the size of the hole and the outside diameter of the bearing. There probably is not a lot of interference, because these bearings are fragile. I never replaced mine, but they can almost be lubed and pressed in cold. Same for the seal.
A bearing driver is best to use, with a little heat and a spray lube coat of anything on the new bearing. It should not be tough, just support the case on the side opposite you apply pressure to the bearing.
  • Similar Content
    • By Josh Munn
      Hi guys i recently bought a klr600 thats was running but had issues the guy i bought it off had fitted a manual timing chain adjuster but it had jumped a tooth and would hardly run i fixed that but it seems like the timing is retarded any one had this issue not sure what it uses as a pick up or if it has an auto advance. Cheers
      I also own a 81 xl185s, 81 xr250, and a 83 xr350. Cheers
    • By CantleyCustoms
      Hello guys,New to the forum.
      Quick question,I have a 1994 klx650c i recently purchased and am in the process of upgrading it.
      Have a trial tech vapor speedo ready to fit,however just wondering about the stock instrument gauges etc.
      Is it literally a case of unplugging the old dash and fitting the Vapor? Is the Dash used to complete the stock wiring circuit? e.g-if i unplug it and leave it unplugged is it going to effect the running of the bike? What about the dash lights,how would i go about wiring these up?
      electrics really isn't my strong point,got the basics covered but way too complicated for me.
      any help greatly appreciated,any more info you need please feel free to ask.
    • By rodrigonehme
      Hello, This is my first post and I'm new to TT.  I recently acquired a 2008 KLR650 (which by the way I absolutely love) and I'm working on adjusting my valves, I already measured its clearances and found this helpful online calculator: however I'm unsure of what the shim factory setting size is and it is essential to get the right shims. Does anybody know what the factory settings are?
      Thank you!
    • By RT_Chris448
      Recently we did a project bike with Dirt Bike Magazine's KLR650 and we were pretty excited about the results.  Check out the article on this fun project here:
    • By DougBurgoyne
      Hey guys,
      A super duper THANKS for all the help, laughs, and fun I've had here, and the bike I put together based on advice and lots and lots of reading material you've provided on what is the best vehicle forum I've ever encountered (been on many over the years). .
      Just when my bike was absolutely the bike I wanted it to be, my riding buddy (who is my father in law) bounced of his DRZ well up 4610 here in Oregon and broke his leg, and good. Tib/fib  job requiring rods, screws, plates, and a kitchen sink to put back together. If it wasn't for the MX boots I got him, and "forced" him to wear....there would have been all sorts of nastiness sticking out of the skin. No doubt about it, as both lower bones broke at sharp angles making spears inside his leg. As it was, everything was contained. He is going to be down for quite some time. I bought my drz to ride with him initially as he had a KLR650 and had an interest in backroad and moderate trail riding. On our first trip out (Brown's camp easy/mod trails) after about 10 times picking up his KLR with over-inflated 50/50 tires (mine stayed on 2 wheels all day long) he said "I need a bike like yours". Within a week he had his DRZ too! Then over the fall and winter we did all the mods and fixes to get them ready for this spring/summer.  It was kind of a miracle I even convinced my wife to let me get a dual sport bike. I'm 50 now, and have a degenerative vision disease called RP. Basically, I'm missing quite a bit of my vision field, but have decent vision straight ahead (unlike macular degeneration). I'm not in denial that good/full  vision is important for safe motorcycle riding on the street...and the reason I'm a 90/10 dirt/street guy. My argument was that we won't get hurt just poking around the woods, old man style, with occasional pavement work to connect trails (thus the need for dual sport over dirt bike).  Well, my father in law shot that theory down, but good!  He has dealt with so much pain over the last month, and met several dual sport riders in for riding injuries (some that make his look like a kid's day camp) that he decided he is out of the game. Unfortunately for me, that means I'm out of the game too. My wife is so worried I'm going to get injured badly, that it's not worth the fight. I don't want her and my daughter stressed and worried every time I go riding. My father in law was doing great on the roads and trails we've been riding. And just loved riding the DRZ. But he's 70 and looking at Jeep Wranglers with lift/tires for his forest adventures going forward. Not a bad call imo.  So...I've sold 2 DRZ's and a KLR in about 1 week (here in Portland OR, I could have sold 4 more DRZ's in the same time if I had them!).  His 1100 Honda shadow cruiser is on C.L. now as he is cleaning out the stable completely. Sad, sad day. It's only been a month since our last ride and I'm already missing the dirt big time. Even sold my daughters doodle bug. Oh well, life goes on.
      Take care guys, ride safe (inside your skill level), gear up...and have some fun for me!!
