Motor oil weight after new top end?
What motor oil weight should I use when breaking in my new top end? I will probably use Rotella T 5-40W after break in but not sure if I should use 10-40W, 10-30W or something else when I break in my new top end. Does it make any difference for getting the rings seated in correctly? I will be using the hard break in method and I assembled the rings and piston dry.
I use regular dino oil 10/40 using the above method.
Ian
