DRZ Idle at 1380-1400...
Does it make sense ?
I've instaleld the TinyTach and it shows the Bike idle at 1400 rpm...
I tried to reach rev limit but since it takes a second to update it looked like bike revved around 9860~ RPM...
Which RPM does your bike Idle ?
Btw , another wierd thing , i start bike , it idle at ~1400 rpm...
I drive 10 minutes and then it shows it Idle around ~1500 rpm...
Anyone ?????
1350 rpm idle when warmed up, according to my tiny tach.
1600rpm more or less steady on my TinyTach...I'm using a FCR39 BTW...I set it for 1600rpm at idle...I like it like that...
Set it with the mixture screw ?
I think that's fine. My IMO shows 1300/1400 when Im just getting started,
and after 10 min, it levels at 1500..
Just adjust it using the idle screw
Probably not the best idea to be checking the rev limit too often with a tach that has a one second delay for readout.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
