KLX 400 Pipe
Has anyone drilled out the baffle on the end cap of the muffler? I was wondering what size and kind of drill bit was used because I don't want to mess up the spark arrestor.
Sure it will be louder with no power gain at all. It's a loser proposition, if ya want hp you got to pay for it. FMF, Yosh, Muzzy, Aproponics, White Brothers. You getting the picture. If I had an S I myself would go Yosh full pipe. At least you get a heat shield that's missing for my K. prairiedawg
Does getting a replacement end cap that has a wider opening give any more power or is that a waste as well?
The biggest gain is to be had in the head pipe design/diameter, slip ons or modifing the stock muffler will yield marginal improvements at best.
No...just more noise. The exhaust system is really not that bad on the S...if you want to make it a little louder just drill three 9/16" holes in the baffle behind the spark arrestor. You'll need a long drill bit. Gives it a throaty sound but does nothing for performance. Unless you do a full system including the header there is not much to be gained in my opinion. Lots of $ spent on just making bikes louder. A slip-on is a slip-on...and if you wanna spend $300 to make it louder knock yourself out... :naughty:
You use a 1 3/8 inch bimetal hole saw, but as posted above why do it? You won't get any peformance gain.
