Fuel Petcock Gasket
Does anyone know where you can get a fuel petcock gastet? Mine has a crack in it so fuel constantly runs to the carbuerator even when it is switched to off. My dealership says they can only order the entire assembly and they want $60. Don't really want to spend that much if I can get the gasket by itself.
Use the old one as a pattern and make one out of a piece of rubber intertube. Just cut it out with a pair of scissors. Or pick-up some rubber gasket material at the local auto parts store. $60 for that little gasket is total BS. I take no liability on this issue...Good luck. :naughty:
You can also buy a small sheet of gasket material at the local auto parts store and make a gasket from that. I always have some on hand.
