Which of these bikes is your primary ride?   3,808 members have voted
  1. 1. Which of these bikes is your primary ride?
    • XR650R
      958
    • XR650L
      1632
    • XR600R
      812
    • XL600
      188
    • Other XL/XR
      164
Please sign in or register to vote in this poll.
4,414 posts in this topic
Can anyone point me in the right direction to purchase axle sliders for my xr650r...i am making a supermoto out of my bike and haven't been able to find the right size or make /model specific slider kits for the xr650r .any advise from fellow riders who has installed axle sliders on the xr650r..whats the best type also in your opinion? Metal? Rubber? Do they make a shaft with just threaded ends or is it just as simple as buying a piece of all thread and cut to fit..i want to make sure whatever i put on they will be durable and not just break off the first time i go down on the bike with em on.. thanks
ImageUploadedByThumper Talk1394463266.849695.jpgImageUploadedByThumper Talk1394463285.315530.jpg
This be my big red. She's getting a new piston and such, that why I have time to list pictures :)
1 person likes this
I used 3/8" all thread in back and 1/4" in front with 4 cheap skateboard wheels and some nuts and washers.
Ya iv thought of doing something similar, but answer me this..
*have you ever been down on the bike with that set up?
* (if yes) how fast were ya going and did they hold up to the crash or just rip right off?
Anyone else wanna chime in on the conversation..what are others doing when purchasing or installing axle sliders on a xr650r? I know im not the first to want to do this on this bike and iv seen store bought sliders or slider kits on these bikes before!
Ummmm, just found this video on the Youtube. Something dont look right :p
is this a joke? Whats up wit the front fork?
My thoughts exactly, I was doing my weekly search for new xr650l videos and saw this video.
It looks like they are trying to sell it. They talked about the fact that the throttle is gone, yet seemingly forgot to mention that the front end is clearly F$#@ed up. Idk, unless I'm missing something that bike is seriously screwed up.
1 person likes this
Im working on a Super Moto project right now! Same bike as the video, but seeing that just made me hurl!
It's been a while since I posted on here gents but thought I'd show a couple of photos taken the other day on the way home from work..........a handy little shortcut!!
Its not messed up that is a new thing changing the rake of the front end so it will cut turns sharper but a little more unstable at speed.....NOT   LOL
It looks like If someone hopped on it and pulled a wheelie, the front end comes down the front wheel jams up in the frame/header and then does a automatic front flip...or at the least the tire gets shredded by the drain bolt...
Anyone else have any input on installing axle sliders on a xr650r what brands have been used and where to buy them? Thanks
  • Similar Content
    • By _RaStA_RoCkEt_
      Hey there, TT. What's good... you been partying? Hope so.
      ANYHOW;
      Ripping my new (to me) 00' XR-R on some fire roads last night up in the Lost Coast and WHAM! There went the chain! It took the OEM case saver and 1/2-3/4 of each mounting bolt with it... which was concerning, but not as concerning as if I had seen the oil draining from a nice new 'modded' hole in the case cover. Yay! (to cheaper repair) No! (to repairs at all)
      Few concerns I have about going through the repair process which seems fairly well documented:
      1) Since I nearly sheared the bolts on the sides of the case, I presume that my bike will need the XR's Only case saver. Fortunately, it uses the rear engine mounting bolt to hold on, but still uses the two OEM mounts as well. The top OEM hole seems deep enough to drill easily... but:
      How far can I drill the LOWER one to re-thread w/out punching my feared 'hole in the case'?
      2) I removed my countershaft sprocket as I sat there waiting for a my AAA flatbed, and noticed that about 1/2 of the countershaft sprocket splines were gone! Further, the retaining ring (w/ the two 10mm head bolts) was worn significantly as well, allowing the countershaft sprocket to do some proper movement...
      Any suggestions on how to fix THAT?
      (I had this problem (#2) on an XR-L, and replaced with a PBI XR-R sprocket to limit wear, since the splines were longer... this seems a bit worse. I ordered, along with the chain, a Ironman front 15T sprocket to replace my worn PBI... but I dk about 'restoration' of the splines on the countershaft itself.)
      Any ideas? / Pictures for the interested... as soon as I find a website that isn't Photobucket!
    • By Jonathan Wall
      Hi everyone I just purchased a 1986 XL600r that was running ok when I bought it two days ago, but would bog down around 1/4 throttle. I drove it around some yesterday staying off the throttle, and she did fine , but not running quite right.  At one point after shutting her down in town, had a real hard time (10 minutes) trying to restart her. I finally got her started and got her home. I tried to fire her up the next day in order to try and tune the carb for the altitude Im at.
      Long story short, she just wouldnt start (wheras before it was very easy to start) - almost like she wasnt getting spark. Well I pulled the plug wire boot and the wire was completely disconnected from the coil! I figured this wire having been super loose while riding was likely the poor throttle issue I was having. Well reconnected to the plug wire to what I think was the coil, then pulled the plug to check that it was super black and sooty. I replaced with a new plug and.... still nothing. Not even close to turning over.
      Whats going on here? My next step is replacing the ignition coil and wire with a new one, but anything else I'm missing here? Thanks.
      edit: this bike had a new stator installed last summer.
    • By TheLastByte
      How the hell are you supposed to get that thing out? I bought that overpriced motion pro tool, tried heating it and soaking it, and it still will not move a millimeter. Do I have to use an impact driver, or do I have to drill the peening out? Can I reuse the retainer once it is out? Can I just loctite it back in later, or should I re-peen it?
    • By MurrietaRob
      This bike has only 249 original miles - is OEM including 1994 red, white, and blue color scheme, bike was garaged and covered and only ridden a few miles a year as it was NOOP registered for past 18 years - bike is street registered now, transferred from family, clean title. Only updates are new D606 tires, battery, and all fluids, etc changed.  Bike is in excellent condition and runs even better; includes original tool kit too!
    • By akitsen
      I'm looking to convert my xr650r to full DC power and was wondering if anyone here was using a terminal bus bar ? something like this one : https://www.amazon.com/DSC-TB01-Terminal-Block-Splits-Input/dp/B005K49NMW/ref=sr_1_2?ie=UTF8&qid=1510464051&sr=8-2&keywords=bus+bar&dpID=310kVzto9uL&preST=_QL70_&dpSrc=srch
      I'm looking to make the wiring a bit more simplified if possible, and have a single organized place like this that everything can connect to and run to battery would be incredibly useful.
      Thoughts ? Suggestions ?
