moving forks in clamp
sorry i know this is a very amateur question but how do you do it? ive done a search on here but couldnt find anything useful
any help is appreciated greatly
Raise front end off of the ground (optional) loosen all pinch bolts on upper and lower clamps, slide forks to desired level making sure both are equal, retorque bolts to spec. As simple as that.
thank you thats all i needed i knew it wasnt tough but im one of those people that can mess up the easiest thing 🙂
the first time i do it they wont be level and ill probably strip up the chinese metal that my pitbike has 🙂
we are going to do it on my friends 1991 Z50 as well does it matter if they are conventional style or USD?
I wouldnt think so. Ive never worked on a Z50 but I would have to assume it is the same procedure.
