oil cap, sring, and strainer!
Does anyone know the order in which the 3 things come together? does it go strainer screen, spring and then cap? or spring, strainer screen then cap? i need to know cuz i dont want to **** up my bike if i do it wrong? yet again i cant find my manual, so help is appreciated. 🙂
Thanks,
wait make sure you put it in the right order... it should look like this
[strainer]---{spring} [O-ring]----{drain bolt}
The long side of the strainer go's inside the spring then put the side with the strainer first into the hole where the oil comes out leaving you the side of the spring with nothing in it facing you.... then just put the oil drain bolt on and seal it
it will go, cap, spring inside cap, strainer inside spring facing hole.
