Taller Bar Installation
I just purchased taller bars (CR-High) to fit the stock clamp (7/8"). Will I have to install new cables? If so, where/how do I go about ordering them?
Thanks
Thanks
Hey Green Man,
No...you will not need to install new cables... I just added 1" bar risers with my CR Hi bars and I did not have any problem...Bill P. did mention that clutch cable may be a bit tight with the risers...move clutch lever in a little...which did help..Thanks Bill P. The risers help tremendously! 🙂 for a 6' rider!
Sangair 🙂
You should be OK like Sangair says. If you do need longer cables, Motion Pro makes them custom if needed.
