Chain Tension
I'm trying to adjust the chain tension on my 230 and i know how to do it but i can't losen the wheel! I've had 20 friends and relatives try and everything i fist tried with a ratchet...then a wrench but the wrench bent almost 90 degrees and now i don't know what to do...any advice on what tools to use and what not. its not that nobodys strong enough to losen the bolt.I seriously think its welded on.
I use a big Craftsmen Ratchet to take the bolt off. The bolt should only be torqued down to 80Foot Lbs. If It were me I would pop it off with an air gun.
-good luck
Try sticking a metal pipe on the end of the ratchet and loosen with that. It gives you loads more leverage. What i personally do is slam my foot on the ratchet to loosen it then tighten it back up with my torque wrench.
I would do what corparate avenger said about an airgun, it might be the best way if you bend your tools doing something different, its weird though, i just use a normal adjustable, then torque it back up.
You could attach the ratchet, have a brave person hold it in place, then come down hard on the ratchet handle with a crow bar. Works for me every time with hard to take off bolts.
Liquid Wrench is a great penetrating fluid that will cut the corrosion that is keeping you from loosening the bolt. Spray it on, let it set for a few minutes and lightly tap the bolt. The tapping allows the penetrant to seek out space with the vibration.
Spray some more, repeat tapping. Take the bolt off.
-good luck
wish I had an air gun, got the compressor, but no gun.....just use a pipe at the end of it man.
That sounds like a good idea. 🙂
