front suspension Ideas?
You could do the spacer trick but you dont have to use washers, you can use thick walled PVC pipe to do the same thing, as long as its the right diameter. The thing I'd do if you can is just buy a set of BBR fork springs. If you only need to stiffen up a little just run one stock spring and a BBR in the other fork leg, thats what I do and its very plush for a 120lb trail rider.
hmm... mind of mencia signature lol
i did that to my ttr90 and it helped a lot. I put 20 weight oil in it and it wears my arms out so i am going to put in 15wt but i am too lazy. I put in 3/4" spacers and it made a world of difference. I reccommend it but it is really truly only a temporary fix because your are compressing the springs more and it will eventually wear them out over time. So plan on stiffer springs in the future. I did it because it was WAYYYYY cheaper to do that than get new springs right now
