KLX300 wide or close ratio trans
Does the KLX300 have a wide or close ratio transmission? I've read where most trail bikes have wide and SX bikes have close ratio transmissions. I'm curious where the KLX300 falls in.
I believe that it is considered a wide ratio tranny.
Ride on
Brewster
I was looking at the ratios in my manual and it looks likes some of the intermediate gears are fairly close ratio. I believe most trail/enduro trannies are like that.
B.
What's the difference between a wide and close ratio tranny? Is it how frequent you have to shift?
Example:
The YZ 250f has a close ratio 5 speed and the the WR 250f has a wide ratio 5 speed. First gear on the YZ is higher than the one on the WR but the ratio spread is closer on the YZ. This gives the YZ quicker acceleration (slightly) than a WR but the top speed is also lower (noticeable)70 for YZ vs 85 for WR. I do believe the KLX has a CLOSE ratio 6 speed which means you get the acceleration of a close ratio 5 speed with the top end of a wide ratio 5 speed 🙂
