Losing Clutch Fluid?
My Riding Partners 525 Mxc Is Losing Clutch Fluid And There Is No Visible Fluid On The Outside, Can It Be Leaking Inturnally?
If So What Can It Be? Any Help Will Be Much Appreciated.
If its the Master Cylinder it will be leaking at the rubber boot, rebuild kit is $15.
If its the hose it can be amazingly tough to spot, it only takes the tinyest leak.
If its the slave cylinder the hydralic fluid will leak into the transmission and you will have a hard time detecting it. I beleive the Oring seal is available from industrial suppy places as well as the dealer. If the bike has thrown a chain and the back of the slave is wounded examine the inside bore carfully, they can get dented on the outside causing a nic on the inside that leads to a leak, and a $100 part.
