Tire info
I've seen some of the bytes about DS tire types but what will actually fit on the back of a 400 zook? 120?130,140,10:50. Anybody had any success with anything bigger than (04-05) stock.
The Teraflex is 150. You'll see some scratches on the side of the knobbies from the chain however. They say this happens only at low speeds, as the tyre's shape will change into an oval at higher speeds.
Here in Europe we regard the Teraflex as a dual sport tyre!
Noppy
You can easily run a 130 mm and most 140 mm tires. I don't like things rubbing personally. Good luck. I run a Pirelli MT21 130 mm rear with lots of clearance. 🙂
here is a better question, does anyone know of a knobby that is too fat for a DRZ?
None that have been reported here at least.
