Unabiker rad guard instal help? CRF450X
I think I read somewere here that their was a redesign on the CRF450X.
If so I may not have gotten the current model.
I know I could get info from unibiker butt I thought I would share here on TT.
My directions say to take off the electrical connection bracket butt don't say anything about it after that.
If I leave the bolt on it keeps the brace away from the frame?
And am I suposed to bolt it on through the shroud bolt or the bracket bolt?
Same thing with the air pump.
I feal I need to do some drilling????
Do I need to cut the shroud where it lines up with the radiator?
Send Brian at Unabiker an email with your phone # and he'll give you a call. I don't think the design calls for drilling or cutting of any stock parts so you'd be better off checking with him before doing anything.
Note: After I took the bracket bolts off to mount mine the fit was much better and if I understand your question correctly you bolt it through the shroud.
Good Luck
S1
OK here is what I did.
I relocated the brackets for the smog pump and the electric conection by just bolting them to the other side of the bracket bolting point.
I used a shorter bolt for the smog pump and a 1/8 spacer for the electrical, it helped with the tight fit. You'll see.
I could see then the brace bolts to the same spot as the shroud.
I relocated the stock bolt retaing clip on the radiator to the front brace.
Then I used thick washers on the top and bottom bolts so everything has the same reveal.
I had to do some fileing on the left side to get the front , radiator and back to line up. I crashed on that side and may have bent it a little though so that may not be a problem for anybody else....
I then trimed the shroud to fit tight against the brace.
To do this I cut down the part that ran vertical against the radiator.
Then dremeled the part that served as a brace for the shroud.
I think these are hondas attempt at a radiator brace built into the shroud.
Since I'm bolting on braces these can be trimmed safely (I think).
And other spots to fit.
Then I was able to bolt the shrouds on without bending or using any spacers.
I did have to use a longer bolt for the radiator because of the extra layers between the bolt and shroud.
I nice thing was the shroud dosn't rub on the frame anymore.
I could post pic's later.
you guys and your californicated bikes
smog pumps on bikes=bs
Bryce
Bryce
Shya what ever dude?
Cough cough uhh hem hem.
I mean no biggie , pump can be removed. It gets a green sticker....
