'05 CRF450 bogging ...
I've gone from a 42 pilot to a 45, added a Quick adjust fuel screw & Boyesen quick shot cover & the thing still bogs out when climbing hills landing off jumps (the bog crashes are starting to hurt)....&%$#@! do I need to do to get the thing from bogging?!!
Sounds more like clip position than pilot. If you are lean on the clip the bike will definitely give you an over-the-bars hiccup when you wick it.
Go back to the stock pilot and try it one clip richer. You can remove the needle w/ the carb still on the bike if you take off the tank, but you really need a ball-end allen wrench to do this because you can only access the needle cover screw (or whatever) at an angle.
Set the needle on a flat surface w/ the open end of the clip facing down and press down. Put the clip on slot further from the top and reinstall...
Hope this helps.
Thanks Hick, I'll try that.
The bogging did get better when I went up on the pilot, so I'll try the needle clip next. Could the float level be off? Bike is new (8) hrs old.
Yeah, the float could be off, not likely but possible. But if it were off enough to result in the bog you are describing you would have other symptoms I would think.
You need to list your Modifications / State / Alt. / Temp Etc...
CRF450X - HOLLISTER HILLS , CA. 500 – 1500’ 50 – 68 Deg.
BONE STOCK JETTING: 168 MAIN / 45 PIOLT / 2.0 AIR/FUEL
APPLIED SMOG REMOVAL KIT
WITH ALL MODS.
JETTING: 172 MAIN / 45 PILOT / 2.0 AIR/FUEL / STOCK NEEDLE # 5 CLIP POS.
ALL HRC MODS “THE WRENCH” (copy at all Honda dealers)
CRF450R MUFFLER With PRO MOTO END CAP – SPARKY ONLY
TWIN AIR COMPLETE AIR FILTER “KIT”
SCOTT EXTEND AIR FUEL SCREW
SCOTT S/S OIL FILTER
CHANGES MADE SO BIKE WOULD LAST: GNCC RACES / FEW G.P. MX RACES:
CHAIN: DID MX520
PRO TAPER CR “HI-BEND”
TALLON HUBS: FRONT / REAR
ECELL RIMS: FRONT / REAR
BUCANON: 8MM SPOKES FRONT / REAR
FACTORY CONNECTION SUSPENSION
SCOTTS/OHLINS STEERING DAMPNER
ACREBIS HAND GAURDS
BRIGESTONE 201/202
RENTHAL REAR SPROCKET
OVERSIZED WAVE ROTORS : FRONT / REAR
ALL HONDA FLUIDS: HP4 10W/40W ENGINE OIL
HP TRANNY OIL 80W / 85W
Troubleshooting
Bike won’t start after a crash
Pilot too lean
Idle set too high
Improper starting procedure
Bike wants hot start button
Bike runs on or won’t idle down when throttle is chopped
Idle set too high
Air leak intake or engine
Pilot too rich (when bike is hot)
Bike won’t start when cold outside
Pilot jet too lean
Air filter is over-oiled
Motor oil too thick for temperature
Bike sputters/won’t clean out at high RPM
Main jet too rich
Spark plug has debris on electrode
Bike coughs and stalls in slow turns
Pilot too lean
Idle set too low
Valves set too tight
Decompressor is set too tight
Bike hesitates or bogs over deep whoops or G-outs
Float level too low
Carb vent tubes blocked
Main jet splash shield not installed
Float level too high, gas is trapped in vent tubes (install T-vents)
Bike starts but won’t take throttle without sputtering
Pilot jet too rich
Water in fuel
Debris in main jet
Bike suddenly starts sputtering/gas flows from vent tubes
Stuck float check valve
Debris in gas or carb
Bike runs hot/feels slow and flat on straights
Main jet is too lean
Fuel octane low, causing detonation
Bike coughs and stalls when you wick open throttle
Needle too lean
Slide cutaway too lean
Pumper circuit blocked or too lean
FYI ~ Moved the clip down one groove on needle, that helped with bog but seemed too rich until I turned fuel screw in 1 turn (now 1 turn out, pilot=45); still a little bog when landing from steep uphill jumps; I think if I change the leak jet from 55 to 52, that should remove it.
Stock except Boyesen Quick shot, screen removed from air filter cage, state=CT, alt.=sea level, temp.=75
If you find a straight and relatively flat road you can try to isolate the different carb circuits and eliminate the effect of the AP by holding a constant throttle position. After a few passes in a tall gear (4th or 5th) you should be able to "feel" where the needle comes on to the taper (the timing of this relative to throttle is what changing clip position does).
Another trick to isolate the pilot circuit is very low throttle runs, and you can tune your idle mix (in part) by trying to eliminate any surging or popping at different rpms w/ the throttle off (get up to speed in 5th, then chop the throttle and downshift).
In my experience it is easier to first try and sort the jetting this way and THEN tune the AP.
Hope this helps.
