New 450X popping & Flame outs?
Anybody have any tips?
I bought a brand new 450x 1st outing overheated pisted coolant, alot poping when getting out of throttle, would flame out and be hard to restart.
2nd outing no overheating but alot of poping getting out of throttle, still flaming out.
thanks
The 450x comes waaaay lean from the factory to pass emissions in CA. Adjust the air screw out between 1.5 - 2 turns from all the way in. That should help.
I agree... air screw 1 1/2 - 2 turns... I put a Zip-ty screw in mine to make it easier... also check your valves... my intakes as well as my buddies where both at 8 instead of 11... that combo fixxed mine..... I had major popping .... didnt Idle well and stalled easy..
now it runs perfect!... no other mods.. excepts guards...
The X is really sensitive to the fuel screw. Seems that I have to play with it every time I go out.
Popping on decel means lean. Open the screw 1/8 - 1/4 turn. Stalling when getting back on the throttle means too rich. Close the screw a tad.
I like the Zip-Ty fuel screw for easy of adjustment, but I have to keep a rubber band around it to keep it from vibrating out of position. Don't know why it's doing it on this bike. Never had an issue like this on the other four bikes I've done this to...
Besides the thins you fellars mentioned, which helped my bike run much better. After I installed the smog block off kit the popping went completely away.
CRF450X - HOLLISTER HILLS , CA. 500 – 1500’ 50 – 68 Deg.
BONE STOCK JETTING: 168 MAIN / 45 PIOLT / 2.0 AIR/FUEL
WITH: APPLIED SMOG REMOVAL KIT
WITH ALL MODS.
JETTING: 172 MAIN / 45 PILOT / 2.0 AIR/FUEL / STOCK NEEDLE # 5 CLIP POS.
ALL HRC MODS “THE WRENCH” (copy at all Honda dealers)
CRF450R MUFFLER With PRO MOTO END CAP – SPARKY ONLY
TWIN AIR COMPLETE AIR FILTER “KIT”
SCOTT EXTEND AIR FUEL SCREW
SCOTT S/S OIL FILTER
CHANGES MADE SO BIKE WOULD LAST: GNCC RACES / FEW G.P. MX RACES:
CHAIN: DID MX520
PRO TAPER CR “HI-BEND”
TALLON HUBS: FRONT / REAR
ECELL RIMS: FRONT / REAR
BUCANON: 8MM SPOKES FRONT / REAR
FACTORY CONNECTION SUSPENSION
SCOTTS/OHLINS STEERING DAMPNER
ACREBIS HAND GAURDS
BRIGESTONE 201/202
RENTHAL REAR SPROCKET
OVERSIZED WAVE ROTORS : FRONT / REAR
ALL HONDA FLUIDS: HP4 10W/40W ENGINE OIL
HP TRANNY OIL 80W / 85W
Troubleshooting
Bike won’t start after a crash
Pilot too lean
Idle set too high
Improper starting procedure
Bike wants hot start button
Bike runs on or won’t idle down when throttle is chopped
Idle set too high
Air leak intake or engine
Pilot too rich (when bike is hot)
Bike won’t start when cold outside
Pilot jet too lean
Air filter is over-oiled
Motor oil too thick for temperature
Bike sputters/won’t clean out at high RPM
Main jet too rich
Spark plug has debris on electrode
Bike coughs and stalls in slow turns
Pilot too lean
Idle set too low
Valves set too tight
Decompressor is set too tight
Bike hesitates or bogs over deep whoops or G-outs
Float level too low
Carb vent tubes blocked
Main jet splash shield not installed
Float level too high, gas is trapped in vent tubes (install T-vents)
Bike starts but won’t take throttle without sputtering
Pilot jet too rich
Water in fuel
Debris in main jet
Bike suddenly starts sputtering/gas flows from vent tubes
Stuck float check valve
Debris in gas or carb
Bike runs hot/feels slow and flat on straights
Main jet is too lean
Fuel octane low, causing detonation
Bike coughs and stalls when you wick open throttle
Needle too lean
Slide cutaway too lean
Pumper circuit blocked or too lean
http://www.factoryconnection.com/index2.htm
BASIC SUSPENSION SET-UP
FORKS
When installing your forks torque the triple clamp pinch bolts to the manufacturer’s specifications (generally 15 - 16 foot lbs.) After you have installed the front wheel and slide the axle through, push down on the handlebars a few times to insure the axle lugs are seated squarely on the axle before tightening the axle pinch bolts. Improper installation can cause binding in the forks and harshness/stiffness in fork action.
RIDERSAG
Measurement A : Place bike on a stand, wheels un-weighted;
measure from the left inside fender bolt to a point on the rear axle.
Measurement B : With the bike off the stand, place the rider w/gear on
the bike in a normal riding position with feet barely touching the ground. Have someone measure between the same two points as before.
• Measurement A - Measurement B
Remember these are only “General” recommendations. Different riding styles, tracks and manufactuer brands may vary these set-ups. However, listed below is a good starting point to choose from:
125-650cc ..... 100-120mm
Too much rider sag indicates you must increase pre-load to the spring by turning the Spring/Pre-load Adjuster clockwise. (decreases rider sag measurement).
Too little rider sag indicates you must decrease pre-load to the spring by turning the Spring/Pre-load Adjuster counter clockwise. (increases rider sag measurement).
FREESAG
Measurement C : With the bike off the stand and the rider off the bike; push down on the back end and let the bike come up by itself. Measure between the same two points as before.
Measurement A - Measurement C (Generally 25 - 35mm)
If you set your rider sag and your free sag does not fall within the recommended range; a spring change may be needed.
HINT: Less than 25mm generally indicates a stiffer spring is needed and more than 35mm indicates a softer spring is needed.
NOTE: 1" = 25.4 mm
OK, now I'm going to show how mechanically pathetic I am. My 450X backfires big time when I let off the throttle. It's especially bad when engine-braking down hill. I looked at the owner's manual and there was no "air-screw" or "fuel screw" shown. I looked at the side of the carb (didn't remove it from the bike) and all I could really see to adjust was the idle speed screw. Where is screw that I should be adjusting, and is it an air screw or a fuel screw? (Sorry I'm such a moron mechanically, but I figure the only way to find out is to ask someone else who has done the adjustment).
Well if the 450X's carb is anything like the 450/R's then the fuel screw should be under/front of the carb, under the float bowl. normally facing the front of the bike. As for adjusting it, You might as well as rotate the carb because getting your hand in there is like sticking your hand in a pond of gators that havent been fed. I like many would really recommend you get the Zipty fuel screw. I makes things so much better.
Thanks - I found it. Definately ordering the zip-ty screw tomorrow.
Same here. The applied racing kit cleared up 100% of my popping
Once you get it installed, throw a rubber band around the end of it and the bowl of the carb. - not a tight one, just enough to keep a little pressure on it. My X seems to like to vibrate the setting loose. Dunno why, as I never had this problem on my 450R or the last two YZFs - just the X bike...
I know I have the 0-ring, washer and spring in correctly too...
Speaking of the o-ring, washer & spring - make sure you get them off the stock fuel metering screw and installed on the Zip-Ty unit in the correct order. - if memory serves (which is a big if!) the order is o-ring, washer then spring over the screw.
Wonder if I stretched the spring a tad... May put enough preload on it to keep the darn thing from backing out due to vibration.
Anyone else with an X seeing this problem? You can't loose the screw - it's stopped by the starter, but what a pain in the arse!
The fuel screw adapters are very close to the top of the starter motor and I think it might hit when the going gets rough. I have looked for marks and haven't see any yet.
Mine sits about 1/16" of an inch above the starter motor. As long as it stays put (rubber band...), it's alright. You shouldn't have any issues with it hitting.
Once nice thing, (as if..) is that the screw can't fall out if it vibrates loose. - the starter won't let it. :applause:
I turned my pilot screw an extra 3/4 out from the stock setting. Now when I chop the throttle, I still might get a little back-fire, but it's about 90% better than when the screw was in the stock position. Is it normal to have a small backfire when you do a full throttle chop, or should I keep turning the pilot screw out until the backfire is completely gone?
i was experincing the same poping last night on decel going down hills, my pipe was also red hot from the cylinder to about a foot down the pipe. Both syptoms of being lean. Would a bigger main jet along with adjusting the airscrew help?
If your fuel screw has a tendency to loosen up, make sure your not beyond 2 turns out...and if not, you can stretch the spring a tad to firm it up. I do this with a pair of stout needle nose pliers and just squeeze it a bit between one or two of the coils.
The reason for no more than two turns is, the window of adjustment is between 1 and 2 turns out. If your on either side of the scale there, you need to move the pilot jet.
