Premix or oil pump (Yamaha)
Hi guys , my son just got a PW 80 and the bike came with oil pump not conected , I don't know if the bike pump 🙂 is working, my question is should I try to fix it or should I continue with mix gaz oil and what can of mix should I use 1/4??
Thanks
You can't go wrong by just runing premix gas.I would just mix some at 35:1 and run it. I have seen more than one injected two stroke siezed up from injector pump problems. Good luck.
My son had a pw 50 that oil pump went out on.I had to replace the top end do to the oil pump failure.After that I always used premix.
