Jet Needle Spacer (washer)
Anybody have a picture of what this mod looks like?
Thanks in advance
sorry no picture but it's a about a 5/16" diameter aluminum or stainless steel washer that is .030" thick. the inside hole is big enough for the needle to fit in. should be able to pick one up at a hardware store. just pull under the exsisting snap ring. it helps eliminate the stalling on sudden throttle off and makes for stronger mid-range. the lean idle can be improved by drilling out the brass plug under the carb and turning the idle screw out about 2 1/4 turns +/- 1/4 turn. smoothed my 2000 right out. to improve the top end you'll have to rejet and open up the aribox.
bol.
steve
