carb diagram??
does anybody have a blowup diagram of a stock keihin carb for a 1999 xr400. ii need to know how to get the the pin to change the clip position. thanks
Someone had an online manual to download that would have it. I can get you started.
You have to remove the cover plate on the top of the carb. You will have to remove or rotate the carb to do this. Then I think you have to remove a couple screws on what Honda calls the link arm to get the needle out.
check out bikebandit.com for microfiche. http://bikebandit.com/partsbandit/assets/schematics/Honda/HJ150036.gif
Pretty much just...
1)Remove top cover
2)remove set screw in throttle valve linkage/throttle drum
3)remove throttle drum/spring (the wheel that actuates the throttle valve)
4)retrieve throttle valve (piston that holds the needle)
5)remove two screws attaching throttle valve linkage
6)remove throttle valve linkage
7)remove needle
Did this two nights ago, so it is still fresh in my brain.
