trailtech wheel size settings??
does anyone know the correct setting for the trailtech computer with 17",s on......i have tried to measure the distance using the guidelines in the manual but it still seems way off?? 🙂🙂
Are you converting your wheel rolling circunfrence in inches to MM? You are looking for a number like 1800 to 2000. Just a rough number - measure dia of tire in inches X 3.14 X 25.4 will give approximate rolling circumference in MM.
does anyone know the correct setting for the trailtech computer with 17",s on......i have tried to measure the distance using the guidelines in the manual but it still seems way off?? 🙂:D
Measure around the tyre using a tape measure, this will give you an accurate dimension.
Neil. 🙂
