250Battery wont keep a charge
2002 TTR250
Recently replaced the OEM battery, as it died and would not recharge, with an aftermarket battery-YUASA
Went to start this afternoon and NOTHING-Any ideas :D on what my be drawing from the battery? The key was left on but nothing was on (lights). I have left the key on in the past without this happening. :D
I have a trickle charger I am hoping that will be enough to get me going tomorrow.
Thanks!
Well, turn the key off for starters. If it works after that, then I guess you have it solved. Check all wires also! 🙂
when you leave the key on it sends power to the ignition box 🙂 and that WILL cause you ignition box to burn up. the power is sent to it and that would drain the battry
Thanks-
It just seemed a little odd that this started happening all at once-Coincidence I guess-
