CR 80 Question!!!!
I just bought a 1996 cr80 in rough shape. I got the bike started and the guy that I bought it from said he just changed the plug. The bike will idle fine, rev fine in neutral, but as soon as I put it in gear and try to move it bogs and dies out no matter what I do.
any suggestions? I put in clean gas, cleaned the filter and plug
Piston and rings.
Any other suggestions, I dont think that is the problem. Shoudl I clean the carb? My dad thinks its clogged
If it hasn't been rebuilt since '96, it's time.
Definately! also, it would always run better with a fresh top end anyways... always good to know when stuff has been done!
check and make sure that the clutch cable isn't stretched and not disengaging the clutch plates when you put it in gear. just another thought
this might sound stupid, but are you giving it gas when you shift until its warm?
does it sound stupid??? yes.. but does it happen???? ALL THE TIME! 🙂
***c so I guess the rings are shot cause I checked everything else. What else do I need besides this???
http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=798m04900&store=Main&productId=p798m04900&catId=&leafCatId=
I dont think the head needs to be honed, So should I use the stock bore? Is this kit all I need? thanks
You should also buy a top end gasket kit.
Did you check your reeds blue?
yeaI checked they seem to be ok.
So just a recap since this is my first time fixing a top end. I need:
Gasket kit,
and the piston kit with piston, ring, circlip, wrist pin?
BTW how hard is it? afternoons worth of work?
Since the bike doesn't have a powervalve it is really easy to change a top end. I know from experience because I had a kx 80 bored to a 101cc and I had to replace the piston every 10 hours. For your first time changing a top end I would take it slow and not rush it but it should take about an hour to do.
Gasket kit,
and a wrist pin bearing, make sure you put a rag or something to cover the hole after the cylinder is off so you dont lose any parts
http://rockymountainatv.com/Product_Details.atv?pid=00023743
http://rockymountainatv.com/Product_Details.atv?pid=00023531
http://rockymountainatv.com/Machine_Details.atv?pid=00024296&cat=ENGI&type=ENGINE&name=Wiseco+Piston+Wristpin+Bearings&make=HONDA&model=CR80R&year=1996&status=
So these three things?
Also will the motor be fairly reliable after this? I just bought the bike for my girl to put around on and for me to mess with/tweak when I have nothing to do
