Carburator question
Hello everyone this is my first post on thumpertalk.com. I have a 1991 DR 650 S. I put a white bros 41 mm f/S tapered bore carburator on to it. And now I have a general carburator related question. I need the adjust the pilot adjustment screw. This screw would be located under a little brass cap right? The tiny brass cap looks like a inside out drain plug would look like on the cylinder head of a car only much smaller. Do I need to drill this out to find the adjustment screw?
Thank you
Mathew watts
if it's an aftermarket carb, usually they don't have a plug over an adjustment screw. do you have any pics of the carb?
