Possible to Remove Head with Engine in Frame???
Is it possible to remove the head (and barrel) with the engine still in the frame? I had a quick look at the manual and it looks like the cam tensioner guide may get in the way or does that need removing to get the head off with the engine in situ.
Thanks
Guy
no you can pull the head with the tensioner in, but you do have to remove the tension on the chain. You may also have to move the left radiator out of the way too so the water pipe on the head can get past it.
