xr70 throttle help
i am having trouble getting the two plastic half moons to seat in that enclosed the twister. I can get the tabs together or the screw holes together but not both. Is there a trick to this . also i noticed a small metal cylinder object that sticks out from the bottom halve of the plastic is this the spacer ans if so can i punch it out
the metal is the throttle cable. most likely your not setting the peices right onto the throttle. set the bottom half on and make sure you can turn the throttel without resistance, then set the top on direcly on top so it matches up with the bottom.
couldnt be easier.... lol
Are you talking about the little piece that sticks up to place it on the bars? If so there is a small hole in the bars that piece fits into. If I were you I'd replace that throttle if you plan on having that bike for any period of time.
