Need to change my fork oil (i'm 160lbs, using stock springs)
how much oil (oz, cc, other method?) do i need & what weight? also what brand??? i have a 98 xr400 so i'm not sure what the spring rate is for that year. do you know? eventually i'll replace the springs but for now i jst want to change the oil out.
thanks!
try 100mm oil height
for spring rate, can check at racetech.com website.
thanks.
i'm keeping my stock springs either way for now, but i will get racetech in the future. i just need oil weight & how much to buy. how do i measure to 100mm??
use 5wt, or ATF(auto transmission fluid) also can.
ya have to collaspe the chrome fork tube down entirely to measure.
from top of the fork, to top of the oil.
hope this helps.
