Question for JD
05 ktm with your kit installed and a honda diaphram as well per your offices instruction. Running the red needle 5th clip position, also installed aftermarket fuel screw to ease in adjustment. My problem is that the bike seems to run very strong for a motor with 2hrs on it but does not idle very well and will die as soon as i crack the throttle. Bike seems ok otherwise, im just in need of your advice or help i can drop it off in your front yard if that works lol : ) Thanks Todd
Todd,
Turn the idle speed up slightly and put some more time on the bike. Adjust the fuel screw each way in 1/4 turn increments and compare. Send me an email if you have more questions about the setting.
(-We could ride it around the yard, but the woods are more fun!)
Thanks,
James
