oil leak from behing sprocket???
hi,,,got oil leak fromn behind the sprocket, we know this is a commen problem, but do u have to split the engine, or do u take the sprocket and put the oil seal in...got me parts order. :applause:
a little trick with spacer, dont try to pull straight out, hose with wd then rotate it in gear with channel locks..
I thought the seal came out pretty easy, the technique is going back together , you'll also need a hand impact screwdriver or kiss them seal retaining bracket screws (elstrippo)
you should have replaced the mild steel spacer with a stainless one :applause:
i have :eek:
HTH
Stainless steel?,,
Has anyone check how the stainless are wearing? if stainless begins to corrode it will do so even faster that regular steel. I haven't had any issue with standard spacer . I did replace my spacer,seal combo at 14,000 mile but the could have gone double that. Present spacer/seal has about 19,000 miles.
I think alot has to do , if you ride in mud and then let it set up in that area.
