changing jetting
becuase whenever i go like in 3 4 5 gears at high revs i dont get the power because it is stutterting and want to fis it and i have done all the free mods exept the gray wire
More altitude means less oxygen which makes your jetting richer. Depending on how high you go you'd want to change to a smaller main jet and raise the clip. Adjust the fuel screw to suit the alt/temp. If you make a big enough altitude change you may end up changing to a smaller pilot jet as well.
