1992 XR250L tank & seat swap to 1992 XR250R
I have a 1992 XR 250L and would like to know if I can install a plastic tank from a same year XR250R. Also if the seat would be an issue. I guess I would like to convert my bike to an XR250R at least the tank.
With enough cutting and welding, you can get anything to fit :applause:
But I think you will find that it's not a simple bolt-on operation. The tanks and seats mount differently between the two models.
Check this out:
XR250L Project
Yes I believe it will fit. I put a '88 "R" seat on my '91 "L" and it fit perfect. I can only assume the plastic tank would work too.
Thanks the clarke holds 4.2 gal but cost $170.00 beans. I guess is not an inexpensive solution after all, I will probably go with the clarke, easy and no guessing.
i was told the mounting for the tank are different
but the seat might fit,
:applause:
