xr 70 throttle spring valve position help
I am having trouble seating the plastic tube that houses the needle jet there are a few slits in it and its cut at an angle at the bottom does anywho know the postion i put this in if im installing it from the shifter side looking at the carb??
OK, I get it now...
The piece you are talking about is metal - it's the slide.
It has a wide ramp cut on one side for the idle adjustment screw and a slot from top to bottom on the other where a pin, inside the bore where it moves, locates it and keeps it from turning.
If you are talking about the slide described above then... when working on the carb from the shifter side the long slot in the slide should face directly away from you, towards the brake side. Good luck!
