ignition
on my new frame theres no where to hang the ignition key, and if i took it off, i dont know how i would shut it off. so where the hell should i put the igniton?
Buy a Moose Racing kill switch and you won't even need the ignition key. The CR style one will plug into the XR/CRF wire harness.
Click HERE, Click on Products, then Hard Parts, then Bike Hard Parts, and then on Electrical.
just turn the choke on where you are ready to shut it down. my friend does that. not the best way but it works for him.
You can bypass the key/ignition but keep in mind when you do this you make it that much easier for a theif.
Also, if you are always around your bike or leave your key in it all the time like most of us... bypass the key/ignition switch by removing and connecting the proper wires together, then install a kill switch which should have come with your handle bar kit.
Good luck and have fun.
