Sticky compression release 2004 450 SMR
I had that problem with mine, deadeye is right, you have to take the valve cover off and make sure the pin in all the way down, my popped up and caused it to stick alittle once I put it back in place everything was fine.
Thanks for all the good advice but this time I just lucky. I grabbed the lever (at the head) and gave it a few movements and it freed right up. Seems to be running fine in fact I just pulled the flame arrestor screen and richened the needle one clip and the low end came alive. This is just with a can and stock head pipe.
Jeff
