Drz subframe
I have just bought the s model.
I removed rear lights to take part in a hare scramble, the rear fender is now really loose.
I s it possible to fit rear fender of the e model and if I did would I be able to shorten rear sub frame.
thanks :D:D
sure... you'll have to hog out some plastic to make it fit. i just put an e rear fender on my s. you'll be hogging out two attach points(for e subframe) and it will be looser than the s fender but you could zip-ty the e fender to the subframe by the little tabs on the underside of the e fender. did you take off the tool bag? that's the rearward attach point for the s fender and would cause it to flop around. some big washers where the tool bag mount base would normally rest, would fix the prob too.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
