XR400 vs CRF450 X
Trying to decide if I should sell the 03 400 and replace it with a CRF 450 X. The electric start is very tempting but parting with the extra cash isn't.
Anybody have any comparisions between the two or mods that might make it worth keeping the 400 or compelling reasons to sell it and move on.
The CRF has a LOT more power amoung other things. It's lighter too. Cuts thru anything like a hot knife thru butter.
The Honda website lists the CRFx at only 7 lbs lighter than the XR. Take the kickstand of the XR, and you will be very close to the same weight.
CRF450x is 5 pounds lighter give or take a pound
Has better suspension stock
The same HP as a xr440
Rebuild it more often meaning more work and more money
Has $7000 price tag
If it was up to me, I would go and look at a ktm300exc. Lighter, more power, better looks, easier to work on, cheaper to work on, and easy to kick. Only prob. is that it may not be greensticker. Im not sure what the laws are on new smokers.
If not that, I would put some money in the xr and if you dont like it then part out the stuff you added and sell the bike. Youre going to spend money either way you go.
the ktm 300exc is a very impressive bike I would definitly look into it
I thought the CRF450 was double the horsepower over the XR??
I have both an XR400 and CRF450X - Both are great bikes - The most noticable diferances I have found I like more about the CRF - Power, Suspension, handling and definetly like the E-Start.
Well a stock xr400 puts out between 32-34 hp.
A stock crf450x puts out about 43hp
A xr440 puts out 44hp from what dirt rider says
Now the crf450r puts out just shy of 50hp I think.
KTM 300exc puts out like 55hp right?
I still can not understand why people have trouble kicking the xr400 over and want a e-start bike? It has got to be one of the easiest starting bikes out there I usually start mine with flip flops on and let the bike warm up while i put my riding gear on. Either your carb is tuned wrong or you don.t understand 4 stroke starting technique
The XR400 is definatly not hard to kick over, but that doesn't mean the E-Start isn't really great to have. Is it worth the extra money? I doubt it. If you're looking for something new, the CRFs suspension is definatly going to be a great upgrade simply becuase the XR's is so old.
It really comes down to your long term budget and how/where you ride. I LOVE my xr440 becuase it has "enough" power (er, i guess you can never have enough..), the suspension is set up great for ME, and its amazingly simple. I put one fluid in it to keep it cool and one fluid in it to make it go boom and i'm set for a weekend of riding. While i'm not proud of abusing my bike, i beat the CRAP out of it every time i ride and i'm consistantly more impressed about how it just won't break. I don't know if you can say this about the CRF, becuase i havn't owned one. Given the CRF450r's short history, i'm sure the X can't be too too much different.
I personally would re-asses what kind of riding you down and consider either working on your XR to suite your riding better, or go after something really impressive like a CRF450r/KTM smoker/Yamaha. Not that i wanna put any bad thoughs in your head, but the WRs are bulletproof, fast, up to date bikes as well. If you see a buddy with one, definatly take it for a test ride.
If you are into survival rides in extremely rough terrain or if you occasionally trail ride in Baja or similar areas then its nice to know that your bike will run fine on any type of left over gasoline you can beg from a Mexican farmer. Also you don't have radiator, hoses, and water pump to be concerned about. With a 4.0 gal tank and good skid plate the XR400 will remain the primo bike for Baja play riding for quite awhile. I own both 650R and 400 and I would take the XR400 over the XR650 to Baja every time. The very large oil capacity on XR400 also adds to reliability on the long hauls. I think both are much better than CRF450s when going is very rough and very long.
Here's my philosophy on the CRF,it is a high rev motor,the XR is not. The piston is only going to go up and down in the cylinder X number of times before wearing the bore/needing maintenance.The shim/bucket valve adjustment is a joke compared to the Xr IMHO.The CRF is fast but how fast do you want to spend? I dont have any problem staying with them on my 440.
i think the xr is a great bike. power seems fine. i've got a 440 kit in with other mods and have no problem keeping up with my buddies on a ktm and wr. granted, we are trail riding and so the speeds are not great. but i can stay wright on there rear wheel or pull away from them if leading. a lot comes down to technique. now in a flat out drag race, i probably wouldn't win. but what fun is it going in a straight line on a dirt bike?
Thanks for all the good info, after what I read I am leaning to keep the bad boy, work the suspension and see how much a 440 kit would be. :D
You should talk to Rob Barnum about getting work done on your bike. A 440 (89mm is actually 435) isnt necccarily better than a 426. A 426 piston is lighter so it will rev quicker and might out accel a 440. Also you don't have to resleeve with a 426 so it keeps the cost down. You can get a 426 piston for $160, bore for about $60, gaskets $25, and a cam if you want bigger gains.
I wondered the same thing. Rode a couple CRF450R's. They ride totally different than the XR. They feel much lighter but at the end of the day, I think the XR is a more comfortable mount for a long days ride. Last year I decided to spend the money and put a joeracer e-start on my Xr400. I love it. And it was a far cry short of $7000 for a new bike.
Hi, I have both and a WR all in different countries. Th CRF is a very sweet bike but a technological nightmare, it really depends on the location and kind of riding you do. I have found th XR to be wonderful in tight snotty slippery trails, single track, and highway riding. very simple comfortable and reliable.
the CRF and WR are both great wheelie fun and fast but when I go out on my own in a forign country in the mountains I would choose the XR just for its simple easy style. It can haul ass too but the CRF n WR will beat it racing. I just sold a KTMEXC300, great dirt bike but after all day it tires you out whereas the thumpers are easier on you. For tight stuff I would go XR.
two things:
people who have trouble kick starting their XR400's are generally people who have modded it and don't quite have the mods set up just right. i watched a buddy kick the hell out of his XR and he was filled with trepidation about whether it would start or flood or what it would do. he has a big bore kit in it and hotcam etc. my XR400 kicks over on the first kick 90% of the time and the second the other 10%, even after sitting cold all week. i never have to worry about restarting it, even after dumping it over.
additionally, i've ridden both the CRF450R and the XR400 (obviously)... this fellow's CRF had the suspension worked by a pro, and i have to say it was amazing. fast, stable, nimble, tracked through sand like it was on rails. it had great throttle response and just felt like it was made to fly. i didn't even notice the close ratio transmission.
that being said, someone already mentioned the pistons being used.
click the link and check that sucker out. almost no shoulder. one of the shops i went to runs 4 CRFs on their team, they change pistons every 6 races. ACK! i guess what i'm saying is-- if you want all the goodies the CRF has to offer, go ahead and buy it without fear-- it IS the machine people say it is. but do it with the knowledge that there is a lot more technology put in place and thusly, more maintenance, more to break, more to keep up with. the CRF, the WR, the RM-Zs, these are NOT the thumpers we're used to, they're F1 cars... the cutting edge of tech. i just rebuilt the top-end of my XR, and after seeing how easy it was, i'd have a hard time giving that up. simple and reliable. but i completely understand why people ride the CRF. in fact, perhaps in a couple years (after honda's stop eating valves) i'd look into one. having both is probably ideal.
with an XR, all you need is a clean air-filter, fresh oil, and good gasoline. 12 pounds in each tire and make sure nothing has vibrated loose.... and YOU'RE OFF!
Amen brother! I've got a CRF250X and I'm scared to death to take it out for all of those reasons above.
Any recomendations in Southern Cal (High Desert to San Diego) who would be a good choice to have the 426 work done on the bike. Give me a hammer and a nail but a wrench doesn't fit my hand.
  • Similar Content
    • By Kev_XR
      If you own an XR250, many of these tips will apply, however, the carburator jet sizes will be different.
      It really helps others answer your questions.
      I will fix them as time allows.
      Until then the Search Feature and enter "kevin's xr400 mods".
      The results will bring up most of the links.
      Here are some frequently asked questions I have answered before.
      Which XR should I buy?
      The longer the straights, the taller the hills, the deeper the sand; the bigger XR you want. The tighter the trail, the smaller hills, firmer terrain; the smaller XR you want.
      The XR400 has a great motor that will pull you almost anywhere. You can be sloppy on a hill climb on an XR400, where you have to keep the 250 singing. The XR400 weight is most noticable when you drop it or try to stop it going down a long downhill. (Moooomentum!)
      The XR250 feels like a mtn bike compared to the XR400. My friend rode his XR250 for years before decided he needed more power. Even then you can add a 300 kit and get good power.
      If you were heading to ride fireroads in Baja, I'd tell you to get the 600/650.
      To the tight woods, get the 250.
      A lot of both, the 400.
      Dual-sporting? Go bigger for more freeway, but don't show up at the trailhead with too big of a bike.
      All of the XR's are great. Pick the one that fits your needs.
      Gordon's Mods for XR400 (Uncorking the bottle up performance)
      XR400 History
      The changes to the XR400 have been listed here several times. This list appears to be complete.
      In addition, HairyScary discusses how to tell if a part has been updated by the part number. Good tip!
      XR400 history
      Getting the Spark plug out
      It seems the MotionPro spark plug socket does not work on the XR400R, but works on the XR250R.
      There is an OEM tool kit being sold on eBay that seems to work.
      717448 XR400 oil change
      Here is a way to make changing the oil much cleaner.
      This tips is really handy if you have a skid plate.
      XR400 oil change
      XR400 FAQ by Paul Gortmaker
      Paul usually has very good info.
      Small bolts
      BE CAREFULL with the bolts on the oil filter cover!
      An oil covered bolt will not torque at the same rate as a dry bolt.
      The friction doesn't build up, the force simply builds until the threads strip.
      This is the reason many people strip out these bolts.
      Here is an execllent website on bolts, oil, and misc values.
      Did you ever wonder why a 8mm box wrench is half as long as a 18mm box wrench?
      It is shorter as most 8mm bolts cannot take very much torque.
      I highly recommend getting getting an 1/4" socket set.
      I bought the Craftsman set at Orchard (owned by Sears), which tends to sell them for less.
      What is the Snorkle?
      This place has a description and pic, it's easy after you pull the seat. I siliconed a piece of coarse screen (fiberglass) over mine to keep bugs and stuff out. - NORTEXT
      717439 XR400/250 Pre-Filter
      After pulling the snorkle, there is a big hole on the top of your XR400. My friend showed me this prefilter trick.
      767409 XR400 Engine Bog, Pilot jet, and the Fuel Screw
      On XR400's twisting the throttle from fully closed to wide open will cause the engine to "bog" or in some cases die.
      831305 Valve adjustment (Am I retarded...)
      Inspect and adjust valve clearance while the engine is cold (35C, 95F).
      Valve adjustment
      389095 bigger jets (Lists stock jet sizes.)
      96-97 XR400's were jetted assuming you would remove the intake and exhaust snorkel.
      98 and later XR's were jetted assuming you would leave them in.
      bigger jets
      739907 Cheap Tool for Setting the Fork Oil Height
      There are some really nice tools out there for doing this job.
      This tool costs $4.49 at Kragen.
      Cheap Tool
      392932 high altitude jetting
      There are two big factors for jetting, elevation and temperature.
      Allen screws for the XR400 carb
      This lists the screws you need to convert the XR400 carb to use allen screws.
      Allen screws
      Screws for the brake and clutch after removing the stock handguards
      TBD - There is a post with the shorter screw part numbers for after the stock handguards are removed. Use search.
      Very quick engine hop up
      This is a very minimal change that should take less than an hour.
      Most of that time is removing the float bowl (3 screws).
      If you decide to do the full "Gordon's Mods" later, you will need to replace the jets again.
      o Pull the intake snorkle.
      o Add a UniFilter.
      o Pilot jet to 55, main jet to 155. (Assuming sea level and moderate air temps.)
      Source: Motocross Action magazine.
      Quick engine hop up
      Gordon's mods
      Baja Designs Baja Baffle with 96' spark arrestor.
      Pull the intake snorkle, UniFilter, 60 pilot jet, 162 main jet.
      (Depending on altitude and temp.)
      What to add to a new XR400 or XR250?
      Acerbis wrap around style handguards (saves levers and bars as they don't dig in)
      Baja Designs skid plate (Made by Utah Sports Cycle)
      Acerbis fork/disc protector
      Grease headset and rear linkage
      Spend you money on the suspension, not a pipe!
      First get some stiffer fork springs (96-97, 98-99 years)
      Fork revalve (cost: 2 qts of oil & time)
      Shock revalve (cost: oil, nitrogen, shim stack, friend who knows shocks)
      Jetting for Altitude (XR400)
      Assuming at sea level and 68 degrees, you would use a 60 pilot and 162 main.
      At 5000 feet and 68 degrees.
      Jettting correction:
      Main 0.96 * 162 = 155 -> 155 main
      Pilot 0.92 * 60 = 50.6 -> 55 pilot
      Due to your elevation, you have less air and less fuel.
      Your bike will not behave the same as a bike at sealevel.
      First, check the fuel screw. If it does not affect the idle speed, you have the wrong one.
      kevin's xr400 mods
    • By Child
      Can we make a sticky thread of pictures? I've done search for pics but I want to see all sorts of bikes just for ideas on stuff without having to go through tons of threads. Not trying to sound whiny or anything, but I think it would be nice to do what they do in the CRF250X forums with a sticky thread of just pics, no comments or anything. Think we can get one of those rolling here?
    • By kawamatt2
      Ok guys, add one more to the list of riders attempting the USD fork swap to an XR frame. Quite a bit of research here on TT and ebay hunting brought me a pretty good deal on a set of forks, triples, and stem from a 00' CR 250.
      There are a few different options for adapting CR style forks to an XR. Bushings for upper and lower CR triples can be made to allow use of the stock XR stem. Specialty bearings can also be purchased to allow use of the stock CR stem in the XR neck. And finally what seems to be the most common; modification of the stock CR stem to allow use of XR sized bearings.
      I obviously chose to pursue the third option for a few reasons, the most prominent of which is serviceability. I wanted to keep as many wear items at possible as stock parts. This has two advantages; availability and price of replacement parts. $45 dollar a pop "specialty" thin section tapered bearings don't sound too appealing especially when being used on a 12 year old dirtbike.
      So now we can get to the meat of the issue; modification of the CR stem. I should begin by saying that i am NOT a draftsman. I've taken a few classes on engineering measurements but am far from an expert and probably only mildly proficient reverse modeling components. With that said, the first order of business was comparing an XR stem and bearings to a CR stem and bearings. Shown below.
      A little closer look at the XR setup.
      And the CR setup.
      Now to get out the calipers and model up the stock CR piece. I used a cheaper set of calipers and suspect their tolerance is +/- .01mm. Good enough for gov'ment work though! All dimensions in millimeters.
      Now to modify the CR stem to work with the XR bearings while remaining compatible with CR triple trees. There are a few things to say about why i did some things the way i did but most of the thoughts are included in the notes section of the drawing.
      With a resized stem we run into the problem of mounting the top triple clamp. The hole is too large for the stem. An insert bushing must be made to resize the hole in the clamp.
      Finally what the stem and bushing look like together.
      Last one. The difference in how the top triple clamp is located on the stem. The CR is equipped with a chamfer that provides a stop for the tree while the XR's triple appears to be limited only by the threads for the castle nut.
      So... would like to hear your opinions on the execution of the stem modification and bushing. I think having these drawings will make it simpler to have the modifications performed as opposed to asking the machinist to completely reverse engineer the part him/herself.
      And a final query: Anyone know the thread callout for the two threaded portion of a stock XR steering stem? My drawings show the outside diameter of the threaded portions and i have a cheap plastic pitch gauge that tells me a pitch of 1.0 but i am looking for something more concrete than what i have.
      Thanks for your thoughts and opinions.
    • By ATJ_Number_1
      I'm on strike 2 here but thankfully this isn't baseball.
      The reasoning and my history. If you haven't figured it out yet I've done a crap load of work on these motors over the last 7 years but they have had 4 wheels around them. In the EX world there are a lot of carburetor options and although many are great there's a cheap alternative that runs 95% as hard as the high dollar options, some even liking it better then aftermarket. When I joined up here in the 2 wheel club I was shocked that the only accepted option was $400 for a 36mm Mikuni Pumper that isn't any bigger then stock! That cheap alternative for the EX is an 04-05 trx450r carb. It's 42mm round slide Kiehin piston-valve with accelerator pump and a mildly modded 400 loves it with a surprisingly strong bottom end yet. Yes I said 42mm!
      So as I build my XR4 I already know that I'd be shooting myself in the foot if I settled on a 36mm carb because I like bigger bores and cams and this motor likes bigger carbs. Makes sense, it is 400cc. Don't get me wrong though, the Mikuni is a real nice pumper for a stock bike and would seem fine on a well modded machine too but this 4 stroke is like every other one in the world in regards to when you go big inside, you want to go bigger outside or you're missing out.
      Whether the info is appreciated or scoffed at I'll post up my findings one by one as I try to find viable alternatives. When I say viable I mean still being able to use the stock environment and not needing a ton of work. I'm sure collectively this is not a new idea to search for such a beast but I enjoy a good project and I like cheap alternatives when they produce results.
      Currently the "test bike" is a 2000 Xr400r, snorkel removed, Uni filter, stock engine, stock headpipe and a 4" supertrapp slip-on with 11 discs.
    • By XL100allnightlong
      Just wondering if there is any tricks to polishing the stock headers on an 02 xr 400 to bring back the original copper color? If not ceramic coating them sounds like an option?
