new carb for xr100?
I need to rejet my 2003 xr100 but I was thinking I dont mind spending the money to get a new carb would it be easier to rejet or put on a new carb?
stock carb works best for stock bore. if you run a 120 kit, you may consider a VM26 or ATC200x carb.
I have a 24mm carb with cable that would work well on a stocker...
PM me if you interested... It will bolt right up...
Even if you put a different carb on, you would probably still need to rejet it.
The carb I have has jets set up for a stock motor and should be effective from sea level to around 900 ft...
For what it's worth...
comes with a new cable too...
