'99 DR350SE - Carb leaking gas into intake
I've read lots of threads about this problem and decided to replace the o-ring on the needle valve. I recently rejetted the carb and noticed the needle seat o-ring was in bad condition. After rejetting, the bike ran perfect for about 2 weeks and then gas starting leaking.
The o-ring is discontinued by Suzuki, so I went to Home Depot and matched it up best I could.
The old o-ring had shrunk to a point where it wasn't sealing anymore. I had gas leaking into my intake manifold and draining out of the bike when parked.
When I installed the new needle seat o-ring, I had to press the seat back into the carb with lots of force. After reassembly, the gas leaking problem was worse.
Question #1: Does the needle seat need to be move up and down? Or should it stay in place?
I figure the o-ring I used is either too big or the needle valve is not sealing and needs to be replaced.
Question #2: What is the root cause for gas leaking into the intake manifold? Leakage at the needle valve or seat?
Any help you can provide will be appreciated. Thanks
