backfire screen
I finnaly removed the backfire screen from my bike, and i was also told to replace the stock filter with a twin-air filter. But the twin-air four stroke model comes with a built in backfire screen! what the deal? why shouldnt i just run the stock filter with the screen?
twin air has a flame resistant foam on the inside. its black in color.
my screen is out. i run the twin airs but sometimes for convenience sake i use the ready racing filters. havent had a back fire. not really much of a concern. just dont wash whatever filter you use with gas and install it right away. wash it out with soap and water first and then let dry before you oil it.
the best part of not running a screen is that it makes it easier to get the cage into the filter and aligning it up.
i run a stock filter with the screen cut out. it has been cut out for about 75 hours and no problems
No reason. I run the stock filter with the wire screen removed (not cut). The best way to avoid a filter fire is to avoid using flammable cleaners and oils on it. I use NoToil, but I'm sure other products (Maxima) are fine.
You are going to burn your bike down.
I run stock filter with The tiwn air filter cage and pro seal gasket. I bought it with this set up. Works perfect so I have no reason to change it.
I'd take that screen out no matter which model. I believe it's a legality.
That's exactly what it is. If you ride a Honda, you dont have to worry.
Take the screen out, you'll be fine. You should note some improved throttle response.
A guy in the 450 forum has a post about his 450 catching on fire. He had the screen in. I guess it can happen with the screen in also.
Was he sitting or standing ?
if your valves start to tighten up, a lot of times you can get valve blow by. It happens more on the exhaust side than on the intake, but it can happen on the intake side. Id just be careful about it. 90% of people including me caant ride this bike for all its worth, then why bother?
90%? naw, try 70% of people.
i run a twin air and the inside foam isnt black
What??? Not sure what you mean.
He was kicking it, and pow fire.
I think they have two types. The regular one and the one with the fire backing.
I understand taking it out has almost no effect. The filter foam restricts the air more than the screen, making the screen, or lack thereof, a mute point.
i have a uni air filter and the screen in so i can or cannot take it out???
:applause: Has anybody seen a Dyno test on the subject? (with and without).
This confuses me here, is the screen where the air filter foam attaches to which connects to the air intake box? Excuse my technical knowledge.
So there's not really a significant gain from this? I've just bought a Twin Filter (white/orange), would I need the screen with it or would it be a safe bet to include it?
*moot* point
your supposed to get added throttle resonse!
