MCCT installation: where did I see those instructions?
Just got my MCCT from APE (Machinist isn't shipping them for now).
Somewhere in the last week or so, I saw a nice write-up on installation and adjustment with pretty pictures and all. But now I can't find it! Can someone please point me to it?
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
