New sprocket
I just put a larger rear sprocket on and my chain is almost long enough. Is there any way to add one link or should I just pony up the 75 bucks and get a new chain. (My existing chain is only about 3 rides old) Thanks for any suggestions.
i don't see why you can't get extra links and slap 'em on, just get a chain breaker and your set :D
I would just get a smaller front sprocket, and not change the rear. You can go down one tooth in the front and that is equivalent to going up two or three teeth on the rear. Your chain will fit with no links added and a front sprocket will cost less than $10.00.
Food for thought. :D
you guys really like the knew smiles eh?
I have known people who have used double master links in these situations.
storyyyyyyy time!
cut chain too short
added double masterlink
chain snapped in about 3rd gear going at a jump IN A RACE
bent countershaft
f-d up gears
food for the thought
storyyyyyyy time!
cut chain too short
bent countershaft
f-d up gears
Storytime. I have known guys who incorrectly installed ONE master link and had a chain snap while going over a jump and busted a case. $$$$$$$$$
Basicly anytime you change your sprockets you should get a new chain. Cause you don't want a worn chain running on new sprockets.
