Rad. Braces
Which one do you think is better of the two? Flatland Rad. Braces or Devol Rad. Braces. Works Connections Rad. Braces should be outlawed.... :D
Flatland hands down. I had Devols on my 450 and there is no comparison.
Flatland!!! Saved two radiators for me already!!! The guards did have to be removed and straightened but much better than buying a radiator!
sweet thnx, does anyone know the cheapest place u can get them?
Don't forget about the Unabiker guards. Very well made!!!
Rooster rad guards - bit it pretty good a few weeks ago and split the radiator shroud... didn't even scratch the radiator itself! :D
Bought the Roosters about three weeks ago. The right side was a major pain to put on. Took over an hour. The left side went on no problem. Oh ya, the right radiator was bent so that's why it took over an hour. The bike was against a tree when it just fell over. I wasn't even on it when it happened and the radiator bent in. If the gaurds were on, there is no way that stupid fall would have damaged the radiator. IMO the Roosters are very well designed to be rigid. Reading the other posts suggest the Flatlands are also good.
So my suggestion is to wait no longer debating which to get. Buy a pair of Rooster or Flatlands soon or your bike my just fall over and you'll be pissed. I was when I realized I waited one ride too long before buying a pair.
flatland all the way. Love the stuff and a great bunch of guys who work there as well.
I've got the Works Connection rad braces on the way, why do you think they should be outlawed?
W/C rad braces are just that, braces. They are not guards like Flatland, Unibiker or Rooster. You want guards if protecting your radiators in a spill is your goal. I have Flatlands but I think the Roosters are better. Scotty
Flatlands are great. I was doing about 50 or 60 mph when i crashed and broke my leg. The left radiator guard took a hard enough blow to almost completely stop the bike and send me flying a good 100 feet at least. It bent in and I had to take it off and straighten it, but it didnt bend enough to even touch the radiator. :D
I have Works Connection braces and they do what they are built to do. They dont protect the front of the radiator. They brace the radiator so it doesnt bend back. They are purpose built and do their job just fine.
Love the Roosters. After getting them on (minor chore) you quickly realize just how made these products are.
I opted to go with Flatland and I'm not sorry I did. I high sided my bike this weekend on a very steep windy rocky climb. I made the climb barely and went to goose the throttle to get on flat ground and bike died :D put my left foot down and there wasn't any ground for miles. Bike went over right on a boulder and I wound up 10 feet down the hill before I got stopped. Picked the bike up expecting the worst and found to my delight zero damage save for 1 scratched decal. While this isn't a full on frontal hit, they did protect my radiator. Flatland has my vote.
I went with the Flatlands for a few reasons.
First, they bolt right on, with no real mods. They fit. (Yes, cutting down the (inside) of the plastic side panels is a pain. Make sure you use a super sharp box cutter, it'll be easier.)
Secondly, they protect the radiator completely, both from impacts in front, as well as bracing them from bending back. The aluminum is much thicker than the WC.
I've owned the WC braces. They're bad for a few reasons:
First, the aluminum is thinner than the Flatlands (I don't know anything about the Roosters).
Second, they do nothing to protect the front of the radiator. Also they require the radiator to act as part of the frame getting pushed back. So, unlike the Flatlands that the guards actually contact the tree (or whatever) in the event of an impact, and then are braced, on the WC the radiator hits the tree and the WC just stops it from getting bent back. Well, the radiator can get bent back in many ways.
Third, they do nothing to protect the side of the radiator from side impacts, again, because there is nothing around the radiator.
Lastly, for almost the price of the Flatlands, why would you even bother?
  • Similar Content
    • By Brady The Honda Guy
      I recently put a newer style fender and plate on my 2007 crf250r. I just had to drill a couple holes in the fender and I used some washer on the back bolts to angle the fender up a bit. Since the original plate mounted with one bolt in the center and the newer styles mount with two bolts, I had to make a custom bracket. Message me if you need dimensions for this bracket. New style is in my cover photo, stock is in my profile picture.
      So I can get a 1986 cr250 motor for a good price and I also know a guy that has a 2005 crf250r that needs work. I have the idea of just swapping motors. Would this motor fit in the newer frame?
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By DirtRider250x
      Hi all,
      My main question is how can I make my 250r more reliable. I have owned it for 2 years and it was spent about 1 year in the shed probably needing new valves and piston rings (i have been putting it off) Will steel valves last longer and work well in the engine? Also, what are your thoughts of me selling it and buying something newer? is it worth it?
