Damn you Kawasaki Engineers!
Did you guys know that the rubber donut that for the valve cover bolts fits perfectly in the sparkplug hole, right over the sparkplug without much of a gap on the outer on inner? Its fits so perfectly that if it falls in there it covers the entire bolt pattern on the sparkplug making the removing the sparkplug to get it impossible?
I think I gotta tip her waaay over and use a toothpick or something????? :D :D
Suicide! It's the only way out...
Dont hate. Just bad engineering, and if you were smart u would use a wrench not a socket.
I see two options out of this...
1. See that small weep hole on the right side of the head. That goes through to the spark plug "shaft". Blow air in there and it should blow out the rubber.
2. Use some grip wire and try to fish it out.
Good luck!
You know I didn't even think of the air hole...brilliant!
I'll take this over trying to install an air filter on my old crf450 anyday...damn honda engineers! :D
  • Similar Content
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
    • By MotocrossMaverick
      Hey guys i have just gotten off my Honda crf150r and i am looking for a new bike. I have been to the dealership and have already checked out the Kx250f and the Crf250r. I am looking more at the Rm-z250 then any other bike right now. I need help finding what bike would be best for me. I have never been on a 250 but i am starting racing about a month after getting the bike. I was also offered $5800 for the Kx250f and i know it killed 2012 i am just not sure about a Kawasaki. Honestly i am not sure bout any please help!!
